Smoke Emitting from Steering Column
Old 08-09-2009, 09:44 PM
W35's Avatar
W35
W35 is offline
Default Smoke Emitting from Steering Column
Every now and again, when I start my car smoke comes out of the steering column until I turn off the car. When I turn on the car again, no smoke. Everything continues to work fine even after the burning, which does not make sense whatsoever. I use my car multiple times a day, but this has only happened 5 times within the past 2 months. Nothing was obviously burnt when I took off the covers to try to have a look.
Anyone had or heard of something like this happening?
Bonus: Picture of my car on an airstrip.
Old 08-10-2009, 06:17 PM
Sorry have not seen that as of yet.
Old 08-11-2009, 10:23 PM
Carrots's Avatar
Have you had any problems with the ignition switch? Such as the key getting stuck, or some of the "clicks" not feeling the way they should? The switches are known to fail on these cars... I've never seen one smoke, but it's a possibility. Suggestion: leave the column covers off, and next time you see the smoke, try to see what part it comes from. The switch is a gray, round piece attached by 2 screws on the left side of the column, below the turn signal switch.
Old 08-12-2009, 08:22 PM
Also to add to Carrots post if the ignition switch is getting worn and going bad sometimes when you start the car the ABS light will stay on. Also the headlights will not work unless you mess with the key.
Mick Maag
1998-2000 model year V70
10-08-2012 07:43 PM
Robonorm
11-05-2008 07:20 AM
rjrcpa
02-03-2008 03:14 AM
jollygoodgold
11-30-2007 07:18 PM
novablue69
12-28-2006 09:57 AM
Quick Reply: Smoke Emitting from Steering Column
