2004 s80 Odometer stopped working
Old 08-06-2011, 10:04 AM
Will56's Avatar
Default 2004 s80 Odometer stopped working
I have a 2004 s80 and the last few week I just noticed that the odometer works sometime, then it quits working. When it does not work the cruise does not work..then the Brake failure light comes on and off ad well as the engine service required light.
This is happening every few days or so, the car runs great and there is nothing wrong with the braking system.
Any ideas?? TIA
Will
Old 08-06-2011, 07:46 PM
lx302's Avatar
The ABS Module/Speed Sensor is going south or you just have a bad connection. Since the check engine light is on, you can scan it for the fault code, helping you pinpoint the problem.
Old 08-08-2011, 08:57 PM
dcm0123's Avatar
Had my ABS controller rebuilt about 8 months ago. Odometer not working is one of the multiple problems caused when this goes bad. It can even cause the air bag trouble light to activate. Never had a problem braking either.
my92940GL
12-28-2015 04:22 PM
newmex999
06-12-2014 07:27 AM
kapka42
07-15-2009 01:14 PM
Keith Tobberman
09-02-2008 08:21 AM
markymarc1981
01-10-2008 10:54 PM
Quick Reply: 2004 s80 Odometer stopped working
