Odometer Stopped Working
Old Jun 11, 2014 | 10:21 AM
newmex999's Avatar
Default Odometer Stopped Working
Reset the trip mileage minder on my 1993 240 the other day and now it no longer works, which in turn prevents the odometer from working.
Is there a fix for this?
Old Jun 11, 2014 | 01:06 PM
brickrunner's Avatar
Mostlikely it is a small plastic gear inside the odometer that broke. It is a very common problem. IPD sells a kit to repair it and comes with detailed instructions. I have never done this but I can imagine that the biggest pain would be to access and remove the odometer from the dashboard.
Old Jun 11, 2014 | 01:14 PM
newmex999's Avatar
Pulling out the unit that houses the clock and speedometer is not bad at all. Pretty much a 5 minute job. Taking out the speedometer and changing the gear- guess I'll find out!
Old Jun 11, 2014 | 01:28 PM
240-FAN's Avatar
There are 6 screws that hold the entire back panel into the housing. Once it comes off the housing, in the center back of the speedo unit are 4 screws. That will get the speedo out of the whole cluster sans the front plastic case (which would have come out with 6 screws). On the side of the speedo unit will be 2 small screws in a diagonal. Remove those and the silver piece will swing like a door. This is where the 2 gears are. The teeth on the small gear usually become brittle and fall off. Also, it is not recommended to push the trip meter reset button if the vehicle is moving.
Removing the speedo and replacing gears will take you 15 mins at most. Cluster removal is also like 10 mins. Very easy
Old Jun 11, 2014 | 01:32 PM
newmex999's Avatar
Nice, thanks
Old Jun 12, 2014 | 07:27 AM
act1292's Avatar
Check out this link. Describes the whole procedure in detail
http://www.odometergears.com/documen...eplacement.pdf
my92940GL
Dec 28, 2015 04:22 PM
Will56
Aug 8, 2011 08:57 PM
kapka42
Jul 15, 2009 01:14 PM
Keith Tobberman
Sep 2, 2008 08:21 AM
markymarc1981
Jan 10, 2008 10:54 PM
