driver's headlight intermittent
Old 01-03-2009, 04:46 PM
poohbear's Avatar
Default driver's headlight intermittent
my wife has a 2000 V40
i've looked through the old posts but didn't see anything that fixed my problem.
i have checked the fuse (driver's side engine bay -10amp) and bulb.
i checked my headlight assembly wiring-it looks intact.
i pulled all the relays under the driver's dash (the ones in the engine bay are labeled and don't mention lights)-none seemed to make any difference to the headlights...does this car not have headlight relays? i've looked for them online to purchase - nobody sells them that i could find...
i'm not consistently getting 12v to the center headlight plug wire at the back of the driver's headlight assembly (according to my multi-meter), but if i bang on the dash (240 style) it will come back on temporarily.
i am going back out and start checking continuity of the wiring harness...but it'd be REALLY great if there was something else to check before i start wiring up a redundant circuit to get this going.
thanks in advance for any ideas,
-chad
Old 01-03-2009, 04:56 PM
poohbear's Avatar
Default RE: driver's headlight intermittent
if i put my meter between the fusebox in the engine bay and the center conductor of the headlight connector- it shows no continuity, then if i bop the dash - the meter will start beeping (signifies good circuit)
i can't hear any clicking like a relay that just freed up (but i am beating on stuff), so i guess it is just a bad connection someplace?
Old 01-03-2009, 08:30 PM
Maybe headlight switch?
Old 01-04-2009, 06:40 AM
poohbear's Avatar
hmmm, do you think it'd have outputs for each headlight?
lemme take a look at it (i've got the dash halfway apart so it should be pretty easy)
thanks for the reply!
-chad
Old 01-04-2009, 07:40 AM
Possible but not 100% sure.
Old 01-05-2009, 12:29 PM
poohbear's Avatar
i checked the switch, there is one output for both headlights and it seems to be working OK. i disassembled it and cleaned/regreased the slider contacts in the fog/headlight switches while i was in there...fwiw
the problem persists.
i saw on another model (v70, i think) forum thread that these "shunts' were possible suspects (pic included) is this a possibility? how on earth do you get them out of there?
thanks for helping me with this!
[IMG]local://upfiles/20531/E215D4D5642A462DA11D1D4997ACD5CA.jpg[/IMG]
Old 01-05-2009, 03:53 PM
The V70 is a different setup.
If you have a little bit of time I will check the wiring diagram and let you know in the morning.
Old 01-05-2009, 06:04 PM
poohbear's Avatar
thanks!
i need to send you a belated christmas present for helping me on this.
Old 01-05-2009, 07:33 PM
Maybe in the morning just bump this post to remind me.(Still have a busy night here)
Old 01-05-2009, 08:45 PM
Ok here is pics of the diagram.
10/7 10/8 is one side headlight
10/9 10/10 is the other side headlight(Didn't specify high or low but most of the legend is missing)
11/2 Fuse box
15/10 relay panel under dash
4/38 CEM
3/2 headlight switch
3/3 turn signal switch high beam switch
Zontar
01-08-2013 08:42 PM
95 850
03-20-2011 07:25 PM
summervi
08-28-2005 11:14 AM
Quick Reply: driver's headlight intermittent
