1998 V70 XC Wagon Wont Start in Cold Weather
Old Dec 29, 2017 | 12:21 PM
BasicPhreak's Avatar
Default 1998 V70 XC Wagon Wont Start in Cold Weather
I have a 1998 Volvo V70 XC Wagon and for some reason, it doesn't want to start in cold weather. When I say cold, I mean 10degress or colder.
I insert the key and go to on and everything works. I turn the key farther to engage the starter and nothing happens I turn the key to as far as it will go and all I hear is one click noise from under the passenger seat.
I got it to start the other day when it was cold, and it did the typical start of a very cold start but once it warmed up it was fine.
I know this is not an issue due to lack of block heater.
Old Dec 29, 2017 | 02:05 PM
Talking **Update**
After research into this, I think my problem is the antenna ring.
Being this problem only happens when the car is very cold, I am trying an experiment of putting a heater inside my car to warm up the interior. I am hoping that it will start when it is warm and I will have to wait till my new antenna ring gets here.
Old Jan 2, 2018 | 02:40 PM
Heater in car didn't help
I am still having this problem
I shot a video of the problem.
Old Jan 11, 2018 | 07:44 AM
Philv70's Avatar
https://youtu.be/kd_38UdRguE
How old is the battery?Despite putting it on a charger or not if it’s really cold and it’s old the cells inside could just be completely frozen and not work even with a charge.Otherwise have the charging system checked. Poor connection plus extreme cold could even start causing issues to the starter motor. It’s certainly not the professional way, but if you use a long 2x4 and knock on the starter motor a bit it may work. It may not, it’s just a thought.Hope this helps!
jpm2346
Dec 23, 2016 02:35 PM
idmclean13
Jan 10, 2016 10:07 AM
oldskoolbrick
Nov 10, 2012 04:58 PM
retrogress
Jun 26, 2011 12:02 PM
arttu
Feb 15, 2007 10:16 PM
