98 v70 battery connected backwards
Old May 5, 2020 | 02:01 PM
1998v70123's Avatar
Default 98 v70 battery connected backwards
hey there, i connected the battery the wrong way on my v70. saw smoke come from alternator within 2 seconds. got back in my car and wasn't getting power to anything except the clock and the kilometres. so i jumped the starter to get it running at the moment. i replaced the j relays and it did nothing. dropped the rad to get at the starter and alternator better and tested the wires. i only had power to the signal wire on the starter and the alternator but not the mains.
Old May 6, 2020 | 07:04 AM
firebirdparts's Avatar
I had a friend who did this, but I ended up not fixing it myself, so I never needed to really investigate it. I have a wiring diagram, and there are no fusible links evident. If something melted, I guess it was by accident. A surge of power went backwards through the alternator diodes, and the wire that carries that is pretty short, and I think can see it all. The problem must be right there. I wish I could help you more.
Old May 6, 2020 | 01:07 PM
Georgeandkira's Avatar
I too am not an expert. I believe the starter's relay is built into the starter and if so, it's not the worst thing.
Since you have to take the alternator to a rebuild shop anyway, just bring the starter along too. Tell 'em what happened so they'll save time.
I never heard the term "j relays" before.
Sure hope you didn't fry any expensive dashboard parts or small "computers".
When you install the repaired/checked-out starter and alternator and reach for the key.....well, it'll temper your character.
Old May 9, 2020 | 06:05 PM
1998v70123's Avatar
thanks for the help, which wire is that your talking about?
Old May 11, 2020 | 10:19 AM
Well, you say you don't have power on all the branches of the positive battery cable. You brought it up in your first post.
dytha99
Aug 7, 2015 01:28 AM
xDread92x
Oct 9, 2014 11:44 AM
x-angel
Dec 8, 2013 10:54 PM
rspi
Mar 28, 2013 09:27 PM
volvoforlife
1998-2000 model year V70
Feb 10, 2013 10:13 PM
