98 v70 wagon question how to figure out if crank sensor or fuel pump is bad
Old Mar 14, 2018 | 09:12 PM
Lumpy's Avatar
Default 98 v70 wagon question how to figure out if crank sensor or fuel pump is bad
All of a sudden engine quit.running and was wondering how to figure out if it's the crank sensor or fuel pump is bad. Any suggestions
Old Mar 15, 2018 | 10:50 AM
firebirdparts's Avatar
If the crank sensor is working, you can read cranking RPM on the scanner. If the cam sensor is bad, after a couple engine rotations I think it'll set a pending code or a hard code for the cam sensor. You can also test cam sensors directly if you have a mind to. Fuel pressure is measured directly, and in fact a tire gauge will fit the test port on an 850. I am not sure if the 98 has a test port, but I think it does. I drive one, but I never really looked at that.
92_240_sedan
Jan 8, 2013 11:23 PM
ZaphodBblbrux
Jul 2, 2012 09:54 PM
Squeaky192
Aug 24, 2010 08:15 AM
bigdaddyrdpjr
Sep 9, 2007 10:30 PM
MattB850in
Mar 21, 2007 12:52 PM
