ETS LIGHT STILL ON runs like crap
Old Jun 8, 2022 | 08:27 PM
jonestr's Avatar
Default ETS LIGHT STILL ON runs like crap
Hello all....
had the usual throttle body ETS symptoms so I replaced the position sensor with the magnet uograde .. 1999 V70 base non turbo 125k miles
Started right up idled fine drove it 3 blocks and ZAPPO
Back to the same Ole rough as a cob running throttle bouncing around etc limped it home
And now what ??
Any ideas appreciated
Thanks
TJ
Old Jun 9, 2022 | 09:46 AM
scan, write down the codes,clear the codes, wait for them to reset and scan again. That should give you some insights as to whether its an ETM issue or something else like a vaccuum leak, fuel pressure etc. Did you clean the MAF when you were doing the repair? Not sure if there is a recalibration required on this model so google around for that as well.
Old Jun 9, 2022 | 10:04 AM
firebirdparts's Avatar
Does it always run well for a minute right after a cold start? Is that your normal?
Old Jun 9, 2022 | 10:34 AM
jonestr's Avatar
Default Ets
Thanks
I am going to replace MASS today
Will reply asap
Old Jun 9, 2022 | 11:52 AM
Okay, have fun!
Old Jun 9, 2022 | 07:24 PM
jonestr's Avatar
replaced the Mass AF and NADA same symptoms HOWEVER i did manage to connect my Bosch piece of junk code reader to the OBD port and Viola
to my surprise i found a 0722 code so now i am leaning towards the speed sensor on tranny to be the culprit
cause i started her back up and it idles ok throttle works just after i drive it , she goes WONKY
Old Jun 11, 2022 | 03:03 PM
jonestr's Avatar
Default Update Saturday HELP
So I replaced the output shaft speed sensor and still no love 💔
It starts up fine idles nice after I erase codes
But as soon as I Rev it up past 4000 rpm or so it goes right Into limp mode and ETS light pops on ??
then idle surges badly
Help
Old Jun 11, 2022 | 07:48 PM
check out the Xemodex's web site for diagnostics on the ETM
JD1965
1998-2000 model year V70
Jan 30, 2022 06:02 PM
lotusing
Jun 19, 2012 01:13 PM
Peti
Aug 10, 2010 08:13 PM
NA850ESTATE
Nov 28, 2007 01:00 PM
louduva666
Aug 23, 2004 06:38 PM
