Oil is puddling on top of engine
Old Oct 17, 2013 | 09:39 AM
paintkicker's Avatar
Default Oil is puddling on top of engine
I have a 1998 V70 GLX, there is a cover over the spark plugs, when you add oil, it will get under and sit on top of hot engine, remove and clean oil and keepit clean
Old Oct 17, 2013 | 03:14 PM
It could be something as simple as a bad gasket under the oil fill cap or it could be that you're due for a PCV system replacement. You might have some backpressure in the engine from the PCV being slightly clogged that is pushing the oil out from under the oil fill cap.
dhodge
Sep 23, 2010 06:09 PM
pacificnw2011
Sep 5, 2010 07:42 PM
97850glt
Engine & Internal
Jul 30, 2010 09:24 AM
Lukeman
Jan 24, 2010 08:01 PM
m1964
Dec 23, 2007 06:24 PM
