2001 v70 t5 p1171 and p1174
Old Jun 20, 2016 | 10:22 PM
Magnusson's Avatar
Question 2001 v70 t5 p1171 and p1174
Hello, I just recently acquired a 2001 Volvo v70 t5 and I recently fixed an oil leak a few weeks back and now a check engine light has lit up on my console and upon further inspection there are 2 codes it spat out. P1171 and P1174, with the little research that it maybe one sensor that might be failing (aka MAF sensor) that might be causing the issue. I need some info to see of what the code is actually saying to see what the actual problem is.
( starts up normally and idles at 700 rpm with no fluctuation and only once in a great while from a dead stop the car surges a bit then goes back to normal when accelerating. I can't decide if I have a heavy foot due to not used to the electric throttle or this might be an actual issue)
MAF is running at 4.5 (g/s) on the live data [ its in metric ]
Thank you to who ever responds.
Old Jun 21, 2016 | 10:02 PM
Magnusson's Avatar
I did a little research for the short term fuel trim and the long term fuel trim and going to post what I am reading from the live data.
Short Term Fuel Trim between -1.6% and 3.9%
Long Term Fuel Trim 21.9%
Old Jun 22, 2016 | 01:13 AM
Magnusson's Avatar
Exhaust smells a bit on the rich side and currently did a reset on the computers by unhooking the battery.
Old Jun 24, 2016 | 06:05 PM
Magnusson's Avatar
Bumping this thread for some help
Old Jun 27, 2016 | 12:27 PM
firebirdparts's Avatar
I have a 98, and I plugged it in and looked at my MAF number. Looks like that number is the same. At idle I am running about 0.6 lb/minute which is exactly the same as 4.5 g/s
So if there's no vacuum leak, then it seems to there might be a disagreement between the front and rear O2 sensors. You should be able to see that in live data. Old O2 sensors drift rich.
Old Jun 28, 2016 | 03:28 PM
Magnusson's Avatar
Well firebird I think I managed to solve my problem. It seems that if a battery is going bad it tends not to burn the fuel throughly and was resolved with a new battery, go figure.
Thank you for the help firebird.
Subvol
Dec 11, 2011 06:56 PM
jimmydean
May 8, 2011 10:32 PM
auto325
Dec 10, 2010 07:47 AM
schott1984
Sep 24, 2010 09:15 PM
