2002 Volvo v70 stuck in park
Old Mar 4, 2019 | 03:47 PM
Terri Michler's Avatar
Default 2002 Volvo v70 stuck in park
My car is stuck in park. I know it's probably an issue with the solenoid. Normally if I let the car warm up anywhere from five minutes to an hour and a half it will shift eventually. However that is not happening today. Transmission fluid levels are fine. I cannot figure out how to get the console panels off and how to get in there to fix this issue and I don't know what tools I would even need to get this done. Can anyone help me?
Old Mar 5, 2019 | 10:05 AM
Did you check for videos on Youtube for replacing the PNP switch? That may give you some ideas on how to get the trim off too.
Old Apr 9, 2019 | 09:11 AM
Jon Snell's Avatar
Behind the gear shift and under the radio console is a rubber pad. Remove the rubber pad, (just lifts out) and use your key to push down in the hole, that will release the gear shift from the park position.
ewgoforth
Jul 29, 2012 09:45 AM
95 850
Mar 27, 2012 06:37 PM
feelnjstfine
Nov 22, 2009 11:04 PM
pfoy
Jul 29, 2007 02:43 PM
big balla
Nov 29, 2006 09:24 PM
