Engine Rebuild (Timing Tensioner Bounce Issue) 2006 V70 2.5T
Old Jul 21, 2021 | 06:08 PM
Wombat Nips's Avatar
Question Engine Rebuild (Timing Tensioner Bounce Issue) 2006 V70 2.5T
Greetings,
I just finished a rebuild on my 2006 V70 2.5T after I bent a few valves from a timing belt snap on the highway. All the valves were replaced, lapped, new seals all around, full-timing belt kit including water pump. I start her up and she sounds great!
The issue comes when I go through a full visual inspection and I see that the timing belt tensioner (Temp Arm) is bouncing back and forth about 2-3 mm. I figure this is not normal and proceed to google the issue... and yes this is not normal. At this point, I have replaced the idler pulley and the tensioner arm and the issue is still present. I'm at a loss at this point.
Perhaps the engine just needs time to break in? More likely I am missing something... Any input is appreciated!!!!
-Wombi
Old Jul 22, 2021 | 01:38 PM
Dingus's Avatar
Did you set the tension correctly? I remember there is a specific process for this. It goes on with little tension and once you're set with the belt back on, you turn the tensioner to a certain time (like on a clock) for proper tension. If i remember correctly there are two different tension settings you can set it to.
Old Jul 22, 2021 | 01:52 PM
Yes, the tensioner is set properly according to temp and torque spec 15 N/m. On another note, the timing belt is riding on the engine side of the cam sprockets. Perhaps a symptom to the issue.
The timing belt is stable (Does not wobble) but, it likes to ride on the edge of the cam sprockets by the block.
Old Jul 22, 2021 | 02:02 PM
Dingus's Avatar
You are talking about the silver piece in the middle with a hex slot right? I posted a photo below. That needs to be adjusted after the tensioner and belt are installed. Just want to make sure we are on the same page
Old Jul 22, 2021 | 02:19 PM
Yes, the silver piece with the 6mm hex cutout is what I used to adjust the tension. In doing so the temp indicator tab (Grey) moved to the center position in between the two silver tabs on the top for a "Warm" engine. Once set I locked down the 12mm bolt to 15N/m that holds the assembly in place.
Old Jul 22, 2021 | 02:53 PM
Dingus's Avatar
Thats about where my help comes to an end, Ive only done two volvo timing belts. maybe just double check that all bolts are nice and tight
Wombat Nips
Jul 21, 2021 05:19 PM
91-740Turbo
Feb 3, 2019 11:06 AM
patrm
2001-2013 model year V70
Feb 28, 2017 11:41 AM
placer61
Oct 6, 2015 12:16 PM
kclarke
Jun 29, 2015 10:54 AM
