ABS light and CEM failure
Old Sep 7, 2014 | 06:07 PM
lakevisitor's Avatar
Unhappy ABS light and CEM failure
Hello, The ABS light on my XC70 was coming on intermittently. I had a used ABS control module put in by an independent mechanic who then took the car to the dealer to have the codes cleared. The car was running fine. While it was being reprogrammed the instrument panel functions ceased and the car would not run. The dealer diagnosed a faulty central electronic module. I had to then replace the CEM. Are the two related or was it just bad luck? Also, I'm trying to decide whether or not to just get rid of the car before another really expensive repair is needed. WHat are your thoughts? Thanks!
Old Sep 8, 2014 | 03:56 AM
doublebug's Avatar
what is MY?
Old Sep 8, 2014 | 07:16 AM
It is a 2005 XC70.
Old Sep 9, 2014 | 01:15 AM
doublebug's Avatar
Unfortunately yes. ABS issue can because of faulty CEM.
Any way it can be repaired. You need to find some good electrician guy.
If you find some PM me and I'll give some tips.
JenniferXC70
2001-2013 model year XC70
Oct 25, 2022 10:46 PM
Fazeel
Forum Issues
Jan 12, 2015 07:48 PM
teedoff70
Aug 9, 2010 09:52 PM
finchy
May 11, 2009 03:59 PM
