'92 740 a/c compressor inoperative
Old Aug 8, 2019 | 09:34 PM
hiflier's Avatar
Default '92 740 a/c compressor inoperative
Hello! Have a '92 740. The a/c compressor clutch will NOT engage when the correct buttons on the a/c/heat control panel are pushed. If I supply 12vdc directly from the battery to the clutch electrical lead, the clutch will engage. Any suggestions? Thank you all.
Old Jan 4, 2020 | 09:25 PM
lev's Avatar
lev
Is there refrigerant in the system? If yes, then the pressure switch on the drier is faulty OR the dash controller is faulty, the circuit board in it most likely. If no refrigerant, then the compressor won't turn on b/c the pressure switch prevents it.
Old Jan 5, 2020 | 10:44 AM
hiflier's Avatar
Default a/c compressor response
You are correct! It was a poor connection of th e pressure switch. Cleaning the connector solved the problem. Thank you all..........BTW....If anyone is watchin this thread, I have a new problem ('91 740 non-turbo) NO SPARK! Any suggestions? Replaced coil & ignition control module. Could it be crank sensor?
hiflier
Jul 7, 2019 12:12 PM
jfg66
Jun 28, 2013 11:03 AM
volksnut
Aug 5, 2007 01:52 PM
hxcboatcaptain
Sep 8, 2006 02:16 PM
mrbyrd
May 31, 2006 09:43 PM
