indicator problems
Old Sep 9, 2006 | 09:52 PM
AK's Avatar
AK
Default indicator problems
HELP!! can someone tell me why my hazzard lights work but my indicators dont? i dont know if it is them indicator arm becasue the headlights still work off it... any answers?
Old Sep 10, 2006 | 01:38 AM
Default RE: indicator problems
Maybe the relay is bad.
Old Sep 10, 2006 | 11:34 AM
AK's Avatar
AK
i was looking for an indicator relay under the hood and couldnt see any all i found was a hazzard lights fuse and that was ok... could it be under the dash? if so which one? lol thanks for the reply
Old Sep 10, 2006 | 12:00 PM
Most likely under the dash.
Not sure what the Year and Model it is if it is a 740 it might be in the Fuse box behind the Ashtray.
Old Sep 10, 2006 | 12:40 PM
AK's Avatar
AK
ok thanks for that im gona go look at it in a bit... is there any chance of it being the indicator arm? also how can i test to see if it is a relay or how do i test if a relay is not working properley?
Old Sep 10, 2006 | 03:17 PM
If you locate the relay and it doesn't click make sure it has power to it.
Then make sure you have power at one wire with the switch in the on position.
Old Sep 13, 2006 | 04:21 PM
AK's Avatar
AK
hey it wasnt the relay i tried fitting a new 1 and no luck, when i first tested the old one it clicked when i had the hazzards on but when i turned the indactaors there was nothing same with the new relay... what should i try check now?
Old Sep 13, 2006 | 08:38 PM
Test with either a meter or Test light and see if you get power to the relay when you move the switch.
It could still be a ground problem by the relay.
Old Sep 14, 2006 | 03:54 PM
AK's Avatar
AK
ok ill test to see if i get power but what do i do if im not getting power? and what do i do if i am getting power?
Old Sep 14, 2006 | 08:56 PM
If you have power then you need to trace the ground circuit.
If you have no power then I would look at the switch.
Old Sep 14, 2006 | 10:40 PM
AK's Avatar
AK
hey thanks for all the help but ive finally fixed the problem it was a fuse that was marked under a different name thats why i couldnt fix it first time i checked the indicator fuse, anyway thats that and if i have any more problems ill be sure to come find you lol, thanks again and hope to hear more from you again...
jsj_297
Nov 5, 2009 09:33 PM
jimny33
May 7, 2005 11:03 AM
stevehill
Mar 18, 2005 06:41 PM
jdbs3
Nov 16, 2004 11:42 PM
