2003 S60 problem with ignition locking
Old Jun 10, 2007 | 01:02 PM
johnv's Avatar
Default 2003 S60 problem with ignition locking
Ignition is locked despite all attempts to gently depress break and depress key while trying to start. Could not engage starter. Cannot get the car out of park. There have been no other problems. Any idea?
Frustrated.
Old Jun 10, 2007 | 03:15 PM
01_fast_ride's Avatar
Default RE: 2003 S60 problem with ignition locking
It could be that the alarm had been triggered disabling the ignition, in which case unlock the car again and all should be good. Or else, is the steering wheel locked? I know in other cars I've owned (hondas, maxima, toyota) I wasn't able to get the key over to the start position if the wheel lock mechanism had set. If that is the case just put your key in the ignition and rotate the wheel in either direction. You should be able to start it then. These are the only two possibilities I can think of.
Old Jun 10, 2007 | 06:27 PM
If the key won't turn at all then the lock cylinder is bad.
CASS60
Jun 16, 2021 01:58 PM
Matthew Esqueda
Feb 21, 2014 01:32 PM
gmanropley
Oct 19, 2012 02:41 AM
mkem
Sep 26, 2012 06:56 AM
