2003 volvo S60 T5 oil pressure
Old Jan 8, 2017 | 08:54 AM
Kevin Lessard's Avatar
Default 2003 volvo S60 T5 oil pressure
Helli people ... This morning i got in my car and noticed on my dashboard de computer wrote no oil pressure stop engine ... What are causes of this message ???
Old Jan 8, 2017 | 06:57 PM
Did you check the oil level? Possible causes are a failed pressure sensor or connector to the pressure sensor, a wiring or connection issue (including fuses), low oil level, debris clogging the oil scavenger - particularly if the light comes on or off depending on engine speed or a failed oil pump. Do not run or drive the car to avoid risking major engine damage - have it towed to a shop where a tech can determine if its as simple as a wiring/sensor issue or if you have a pump problem.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
nuclearseal
Aug 17, 2022 01:48 PM
EivlEvo
Jan 8, 2016 03:32 PM
brettboze
Mar 26, 2012 06:25 PM
czechster
Mar 2, 2009 02:55 PM
