99 volvo s70 idle problem
Old Apr 29, 2006 | 12:02 AM
guyjrcindy's Avatar
Default 99 volvo s70 idle problem
I was wondering if anybody has ran across an idle problem on a 1999 volvo s70 turbo. Whats going on is it starts to surge up and down and whats really strange is it does not do it all the time. The car runs great down the road, I already replaced the fuel filter and used some injector cleaner, someone helpppppppppp, Thanks.............
Old Apr 29, 2006 | 01:48 AM
Default RE: 99 volvo s70 idle problem
Clean the throttle body and see if it helps.
If not the throttle body is going bad. The warranty was just extended for 10 Years 200,000 miles.
Old Apr 29, 2006 | 02:26 AM
S70turbo1999's Avatar
i have the exact same problem and i got a letter about the ETM warranty being extended. It said the warranty covered unstable idle or something like that, so im taking it in when i get the chance to get it fixed
Old Apr 29, 2006 | 12:13 PM
guyjrcindy's Avatar
I'll give that a try today and see what happens. Thanks I'll let you know
Old Apr 29, 2006 | 12:22 PM
We will wait to hear from you.
Old Apr 29, 2006 | 05:24 PM
also, what would it cost to get a new wheel well installed and everything, mine was torn in half by a renegade screw on a parking cement thing? i figure id get that fixed when i go in for the ETM
Old Apr 29, 2006 | 05:57 PM
The inner wheel well or the Air Guide?
Old Apr 30, 2006 | 02:22 AM
the inner wheel well i think. its the plastic lining connected to the bumper, which is causing my bumper to be a little loose.
Old Apr 30, 2006 | 10:55 AM
You might have unhooked the bumper cover on the end.
The wheel well goes from the front bumper where it is riveted to the rear of the inside of the fender by the Door.
The Air guide goes across the front of the car.
Old Apr 30, 2006 | 02:36 PM
yea its the inner wheel well then and it is basically torn in half. duct tape is now hold it together
Old Apr 30, 2006 | 05:51 PM
Probably cost about $100.00 or a little more for the part and labor.
ynotgio
Jan 13, 2014 10:30 AM
spiel2
Jan 21, 2010 03:16 PM
ss~zoso~ss
Jan 12, 2009 04:27 PM
toshields
Dec 8, 2007 04:50 PM
