Can't open fuel filler door
Old Jan 10, 2010 | 02:24 PM
bschulman's Avatar
Default Can't open fuel filler door
I hope someone can help me. I've got a 2001 Volvo V70, and I can't unlock the fuel filler door.
We've recently had some brutally cold weather, and I've encountered several quirky electronic problems--and I think they happened at the same time.
  • I can't lock/unlock the rear locks.
  • The fuel gauge always reads empty.
  • The rear windshield wipers don't work.
  • I can't open the fuel filler door.
I can live with everything except not being able to open the fuel filler door.
The fuses are okay. I can't find the motor for the fuel filler door, and I don't think there's a manual release.
I'd appreciate any straightforward suggestions.
Thanks!
Old Jan 10, 2010 | 04:41 PM
I assume that it's the same as my '95 850 that has a pin that slides through a tab with a hole in it that is part of the door??? Well, I had the problem a couple of times. My door tab was putting a little pressure on the pin and would not let the pin slide OUT when the doors were unlocked. If this is the case, push in on the door a little when you unlock the car with the remote. If that doesn't work, try pulling on the door a little when you unlock it.
Either way, you should be able to access the locking mechanissim from inside the car/trunk somehow. Behind a panel or the material inside the car/trunk.
Old Jan 10, 2010 | 06:39 PM
bschulman's Avatar
Default Thanks, but suggestion doesn't work
Great idea, but the remote doesn't work--I have to unlock the car with the key.
Also, I couldn't find an uncomplicated way to remove the interior panel near the fuel filler door.
Any other suggestions?
Old Jan 10, 2010 | 08:25 PM
Most of the material in Volvo's are just tucked or held in place with pressing clips.
As for locking and unlocking, you may need a helper.
Old Feb 16, 2010 | 04:58 PM
Big wave Wayne's Avatar
Default v70 fuel filler door won't open
I have a 2002 v70 xc & fuel filler door wouldn't open from the dash button. Fuse was ok so you have to open the little door in the cargo area, passenger side, remove the 2 composite covers ( 1 pulls out the other has a clip) supposedly there is suppossed to be a stainless steel wire connected to the solenoid that opens the door.......not on my car, but I was able to reach my hand up to the solenoid & pull the plunger back and the fuel filler door opened.
Old Oct 16, 2018 | 02:23 PM
MikeStone's Avatar
Default Fold down back seat release in the trunk
I pulled the back seat fold down trigger in the trunk. It was actually the drivers side release which caused the fuel filler door to open right up. I have a 2001 S80.
SpiringData58
Aug 4, 2018 06:22 PM
Sssnake
Jan 9, 2014 10:15 AM
qcvol
Jun 17, 2013 09:55 PM
bschulman
Jun 22, 2011 05:16 PM
ibified
Nov 22, 2010 06:36 PM
