Fuel door button?
Old Aug 2, 2018 | 12:49 PM
SpiringData58's Avatar
Default Fuel door button?
Hey guys just bought a used volvo s60 from another owner and it's a 2001 volvo non turbo aside from everything working the way its supposed to there is no fuel door button.... like anywhere.... you can literally walk up to the car and open the door. Any suggestions?
Old Aug 2, 2018 | 02:04 PM
ES6T's Avatar
The fuel filler door is locked with the car.
Old Aug 2, 2018 | 02:32 PM
No it's not I can walk up to my car with it being locked and with ease open the fuel door
Old Aug 2, 2018 | 03:09 PM
tony1963's Avatar
I think what ES6T is trying to tell you is that there is no "unlock" button like on the later models. The default position is open until the car locks. If you can open the filler door with the car locked, then either someone has broken the tab off the fuel door catch or the lock mechanism is defective/disabled.
Old Aug 2, 2018 | 03:16 PM
How would I get in there to fix it myself because I would much rather not go to a mechanic and have them fix it and charge too much
Old Aug 2, 2018 | 03:28 PM
tony1963's Avatar
If you pull away the trunk paneling on the RH side, you'll see the mechanism in there bolted to the body. Get a good flashlight in there and you will see how it is attached. My guess is that someone already unplugged the solenoid but changing them is pretty easy. They are not expensive to replace.
Old Aug 2, 2018 | 04:05 PM
ES6T's Avatar
Another common problem is the fuel door hinge cracks. This causes no tension to hold the fuel door closed. The causes the lock rod to not fully engage because instead of going through the hole for it on the fuel door, it hits the tab and does not lock.
Old Aug 4, 2018 | 06:22 PM
abdullahcfix's Avatar
I don't know if it's the same for your car, but in my 2004 S40 1.9T's manual, it says that the fuel door remains unlocked for 10 mins after you lock the car. It locks after that.
bschulman
Oct 16, 2018 02:23 PM
Simtech
Jan 31, 2012 07:32 AM
bschulman
Jun 22, 2011 05:16 PM
ibified
Nov 22, 2010 06:36 PM
fernandos1
May 24, 2008 03:21 PM
