Engine swapping an S40 help?
Old Dec 2, 2015 | 06:10 PM
Dimitri's Avatar
Default Engine swapping an S40 help?
I have a 2004 MK1 2.5L 5 cylinder auto S40, I like it a lot, quick, nice handling, I just want to make it quicker.
Here's my question, do any of you know what engines will actually fit into the engine bay without a whole lot of grinding and everything?
Or would it be better to just fit duo turbos and a k&n filter + cold air intake?
It's kinda hard to find engine swap information on this car, so I figured maybe someone on here might be able to answer my questions.
Old Dec 9, 2015 | 06:51 PM
Does the car have a turbo in it now?
Old Dec 10, 2015 | 05:39 AM
Dimitri's Avatar
Yes it does.
Old Dec 10, 2015 | 12:36 PM
Tara Jones's Avatar
Hi there can anybody help I've blown the engine in my s40 t5 can I put a s60 T5 engine ?????
Old Dec 11, 2015 | 02:30 PM
Cdubbs's Avatar
Originally Posted by Dimitri
Yes it does.
What are your power goals? That can help determine what you need in terms of hardware, but if you're looking for just a little extra horsepower then maybe look into retuning the ECU and a few simple bolt-on mods and increase the boost on your current turbo.
I'm not too familiar with swapping FWD motors, with RWD cars you have more liberty to swap engines and transmissions.
Old Dec 11, 2015 | 11:15 PM
Dimitri's Avatar
I'm looking to get around 300-350 hp, but I'm not sure if the current engine would be capable of outputting that with some bolt-on mods.
Old Dec 14, 2015 | 10:14 AM
Cdubbs's Avatar
If there is enough room, I would maybe consider a Honda V6 platform such as the J32. More displacement and another cylinder plus lots of aftermarket support.
Although these days with modern ECU tuning and fuel delivery, small displacement turbocharged motors can push a lot of power and do it reliably. Lots of tuners have cracked the factory ECU so you don't have to rely on standalone engine and fuel management and the car will behave normally, won't throw error codes and check lights etc.
taygarde
Nov 19, 2012 09:03 PM
vonzai
Jul 1, 2011 11:19 AM
phaedrus
Jun 7, 2011 11:44 PM
rcartlidge
Feb 10, 2010 10:48 AM
lwrdr2
Nov 23, 2008 06:35 AM
