Have a huge problem.
Old Jul 31, 2016 | 08:13 PM
Battleship's Avatar
Default Have a huge problem.
I was driving from Alabama to Washington and first the car warned to check coolant. When i opened the hood no coolant was in the resivior then when i tutned the cap it filled up. So i turned the car on and opened the cap with it running and filled the resivior all the way till it stopped. Then today i was driving and suddenly no power at all. Coolant all over the road. What should i look at first?
Old Aug 1, 2016 | 11:39 AM
firebirdparts's Avatar
Fill it back up and see if it'll run. If it runs, then observe where the water is pouring out. That's what I would do. The water may pour out even if it's not running, which would be great at least for diagnostic purposes.
It's possible to pressurize the cooling system and find leaks that way, and very effective, but I assume you don't have the tools to do that.
Old Aug 1, 2016 | 11:43 AM
Battleship's Avatar
Originally Posted by firebirdparts
Fill it back up and see if it'll run. If it runs, then observe where the water is pouring out. That's what I would do. The water may pour out even if it's not running, which would be great.
Had to scrap the car because upon further inspection, the cooling system had an air bubble in it and the water pump exploded taking the timing belt with it out the side of the cover. I looked online and it looks like she was an interference motor.
xxMAXIMxx
Engine & Internal
May 28, 2008 03:08 AM
crising
Feb 13, 2008 06:56 PM
Joe 850 Bird
Jul 23, 2007 09:39 AM
rp850
Jul 22, 2005 03:36 PM
940P71
Nov 16, 2003 10:17 AM
