Headlight Lens
Old Mar 3, 2007 | 01:28 PM
BobDog15S70's Avatar
Default Headlight Lens
I had a rock go through my right front headlight lens. I was able to get a new lens (not the whole assembly), but it not come with instructions. I can kind of figure out that in involves taking off the old clips, but I am trying to find instructions for attaching the new gasket to the new lense and the best way to get the new clips on without having to pull off the whole headlight unit. Any help???
Thanks!!!
Old Mar 3, 2007 | 01:29 PM
Default RE: Headlight Lens
It will be easiest to remove the headlight.
The gasket slides into the grove in the headlight assembly.
Since I assume you have a S70 by the screen name it is easy to remove the headlight.
Old Mar 3, 2007 | 01:32 PM
I do indeed have an S70. What are the basics for removing the headlight assembly. It's a 1999 by the way.
Old Mar 3, 2007 | 01:49 PM
Remove the side light. There is a tab that releases the side light. Becareful doing it. Sometimes they will break. Look from the top you should see the tab. You will have to push it down and slide the light foward.
Then there is 4 10MM nuts holding the light in the car. remove the nuts and the light will come out.
Old Mar 3, 2007 | 05:05 PM
S70driver's Avatar
There are actually 3 10mm bolts on each side holding the assemblies in place.
Old Mar 3, 2007 | 08:37 PM
Thanks to all! Install was a snap and a BIG savings versus having a new assembly bought and installed.
Old Nov 1, 2007 | 09:31 PM
GreyBach's Avatar
How about for a 2000 V40? Anyone replaced the headlight assemblies in this model? I'm changing bothout this weekend and could sure use some insight. What all needs to come off to get to them?
Thanks!
ORIGINAL: tech
Old Nov 2, 2007 | 05:46 PM
You need to loosen and slide the front bumper cover out some to get the Headlights out.
skyman
May 5, 2006 06:57 PM
branse
Dec 20, 2005 11:13 PM
OverTheTop
Nov 30, 2005 11:56 PM
gidish
Nov 1, 2005 08:10 PM
banani
Sep 21, 2005 10:19 PM
