Help!! 2006 S80 fuel system problems 4 clogged fuel filters , fuel pump
Old Dec 26, 2017 | 06:27 PM
premix's Avatar
Default Help!! 2006 S80 fuel system problems 4 clogged fuel filters , fuel pump
My wife's S80 started leaking fuel from the sending unit a few mouths ago and has not been the same since. I replace the o ring a few times the pressure sensor, fuel pump and it keeps clogging fuel filter??? I am on the 5th fuel filter. What is going on. When I changed the last filter the fuel was black/ dark gray with a very fine silt in it. Has any one seen this. Is part of the fuel system braking down and clogging the filters?
Old Dec 26, 2017 | 08:10 PM
more likely you got some sediment from a gas pump (possibly from a fill up while the station was being filled by a truck). you may need to drain and clean the tank.
joedirt
Oct 10, 2017 07:13 PM
Volvo_Neps
Oct 9, 2013 09:33 PM
grndslm
Apr 14, 2013 05:03 PM
movistardave
Jan 20, 2013 12:07 PM
jholst
Jan 31, 2011 01:18 AM
