Highway vibration
Old Sep 22, 2007 | 04:42 PM
buzzforb's Avatar
Default Highway vibration
I would like to start by saying what a great resource this is. Great information combined with good organization. Thanks for all the recent help. That being said, I need some help. I drive a 95 850 non-turbo wagon. I recently put new lower control arms, new sway bar links, new axles, and new tires with alignment. My problem is that i am getting a vibration in the steering wheel on the highway. I do not have any trouble below 50- 55mph. Any suggestions?
Old Sep 22, 2007 | 05:20 PM
Default RE: Highway vibration
Have the tires rebalanced. Or a tire might be bad.
Old Sep 22, 2007 | 06:51 PM
buzzforb's Avatar
Is it posiible that i might have bent rims. I think someone once told me that i had two that were bent. Should't that show up in the balancing process.
Old Sep 22, 2007 | 08:43 PM
JPN's Avatar
JPN
Hi buzzforb,
Bent may show up on a dynamic balancer but the balancer may not report it as damage and a technician can install balance weight and the problem can get masked until the tyre wears a bit. Many people seem to lift the front/rear end of the car, turn the wheel while placing a piece of wood close to the tread surface to check for out-of-round. Visually inspect the wheels, and if you do not see large dent, it is probably ok but follow moderator Tech's advice.
Also, I would double check the hardware (nuts & bolts) for looseness, and check the ball joints & tie-rod ends to see if the rubber boots are torn. Lastly, check the tyre pressure, though this probably has nothing to do with the symptom.
I hope this gets you started.
JPN
cjaama
Apr 26, 2010 08:20 AM
oddlots347
Jan 11, 2009 05:03 PM
ocean238
Apr 17, 2008 06:20 PM
danrashba
Jul 27, 2005 10:06 PM
Liz_XC70
Jun 30, 2005 07:56 PM
