Passenger door mirror with camera properties
Old Oct 10, 2023 | 06:58 PM
trainlover's Avatar
Default Passenger door mirror with camera properties
What features are controlled by the passenger side mirror? The mirror was damaged and the completed mirror was removed/unplugged. I learned the air conditioner is nonfunctional without the passenger door mirror. The ambiant dash temperature fails to operate which is controlled by a sensor in passenger door mirror which shuts the ac down. What else is affected? Possibly the blind spot indicator for the entire car? Thanks
Old Oct 10, 2023 | 07:22 PM
There is a temp sensor in both mirrors. Apparently the right sensor is for the ac and outside temp gauge. As you have found it is needed for the ac to know to produce cold air. You might be able to turn the temp all the way cold to make the compressor come on (temporarily)
The blind spot indicator camera just turns on the flashing light on the inside of the door on that side.
porky1
Feb 5, 2015 05:51 PM
KonaKula29er
Aug 15, 2014 05:23 PM
Falasi4
Mar 5, 2012 10:06 AM
jose57
Dec 3, 2007 05:37 PM
Esercitare
May 24, 2006 08:36 PM
