Stearing column and ignition broke?
Old May 21, 2007 | 02:52 PM
jbuelow's Avatar
Default Stearing column and ignition broke?
I have a 1999 s70. They key wont turn when in the ignitionand the stearing colomn won't turn, wheels just keep turning even though car is off and no key in the ignigiton. They shift is all the way up cant even budge it, and the shift overdrive is off. Any ideas as to what is going on?Any one help? Please....
Thanks,
Jess
Old May 22, 2007 | 12:01 AM
JPN's Avatar
JPN
Default RE: Stearing column and ignition broke?
Hi Jess,
Greetings from Yokohama, Japan but lived in Chicago until February.
I was not able to comprehend yourquestion 100%, it seems like just a steering lock problem, but then you say the wheels keep turning?
If the shifter doesn't want to shift out of park, it may be either the PNP switch or the micro switch.
As I'm an 850 driver, I am not privy to S70. Post this question (I recommend that you restate it to be a bit more accurate as to what symptoms you're having) in the S70 forum to receive better & accurate answers.
I don't know where in Chicago you live. I only lived there for 11 months and did most of the repairs by myself, and the only reliable shop I know is the dealer where I had 4-wheel alignment. The dealer does charge a lot, but the job would be done the first time (unless they figure you are an easy target):
http://www.patrickvolvo.com/index.htm?bhcp=1
This dealer is in Schaumburg, they have Volvo, Saab and Cadillac.
Good luck,
JPN
Transx
Mar 7, 2010 08:16 AM
dbheatherly
Nov 27, 2007 06:24 PM
rhcprox123
Nov 26, 2007 11:58 AM
novablue69
Dec 28, 2006 09:57 AM
