Ignition column/switch replacement
Old Nov 20, 2007 | 12:42 AM
rhcprox123's Avatar
Default Ignition column/switch replacement
i have a glt s70 and today i stuck my key in the ignition but it wouldn't proceed past the I position and remained locked. I tried jiggling it around in hopes that it would ignite but it didn't it remains locked. I'm not sure whether its the whole ignition column or just the switch ( if they are the same im sorry for my ignorance). If so, is there a site where there is a diagram showing how to do this and if there is is it difficult? or would it just be worth it to have a professional do it and the costs of labor and parts? thanx
Old Nov 20, 2007 | 02:22 PM
Eric J's Avatar
Default RE: Ignition column/switch replacement
Try one of your spare keys first.
Old Nov 20, 2007 | 03:38 PM
rhcprox123's Avatar
i tried this but still no luck.
Old Nov 20, 2007 | 06:47 PM
Usually the lock cylinder assembly is bad when this happens.
Old Nov 20, 2007 | 08:55 PM
rhcprox123's Avatar
i think its the ignition switch..instead of getting a stock switch could i just bypass getting the shipped parts from the dealer and just get a push start one and would that work?
Old Nov 20, 2007 | 09:52 PM
What year?
Old Nov 20, 2007 | 09:58 PM
rhcprox123's Avatar
1998 GLT 2wd
Old Nov 20, 2007 | 10:00 PM
You might but remember your car has an immoblizer.
Also how would you lock and unlock the steering wheel?
I would reccomend replacing it with the proper parts.
Old Nov 21, 2007 | 11:11 AM
rhcprox123's Avatar
yeah today i jsut purchased a new ignition lock cylinder from the dealer for 140 bucks..hopefully this does the trick
Old Nov 26, 2007 | 11:58 AM
It will I have never seen anything else cause the problem.
jbuelow
May 22, 2007 12:01 AM
novablue69
Dec 28, 2006 09:57 AM
