Winter mode
Old Jan 13, 2007 | 09:01 PM
prienn's Avatar
Default Winter mode
New '01 V70 owner as of two days ago. From what I've read on here, Winter mode starts the tranny off in 3rd. Is that all it does?
Thanks!
Old Jan 14, 2007 | 01:02 AM
zmontgomery's Avatar
Default RE: Winter mode
That's what I'm told it does on my 960. It really helps when its super icey.
Old Jan 14, 2007 | 03:42 PM
JPN's Avatar
JPN
Hello prienn & zmontgomery,
Greetings from Chicagoland,
In general, winter modes lets you start in 2nd or 3rd gear, that's all there is to it. This reduces torque at the drive wheels and prevents them from spinning. In some cases, normal mode gets you out of snow better, while on icy surfaces the winter mode may work better, as Mr. zmontgomery has noted.
As in the case of 850, according to the owner's guide:
WINTER MODE:
In this mode:
*In position D, the gearbox starts in 3rd gear and changes up to 4th gear.
*In position 3, 2nd gear is locked and there is no change up to 3rd gear.
In position L, 1st gear is locked.
*These positions always offer kick-down function.
Traction control (TRC) works by controlling the throttle & brakes,which are operated byon-board computer. In some cases, turning off the TRCgives you better traction (going uphill, etc...).
ABS works by turning the brakes on/off via on-board computer. ABS does not reduce stopping distance, it only allows you to steer in case of panic braking on slippery surface. In heavy snow,normal brakes sometimes work better, as snow builds up in front of the tyres.
Enough burble I guess.
Good day,
JPN
prepg
Jan 21, 2020 06:44 AM
fadam
Oct 16, 2017 06:27 AM
cool_kyle_3000
Aug 26, 2008 07:05 PM
tupapison
May 12, 2006 11:26 PM
fatduck
May 9, 2006 12:06 AM
