1996 volvo 850 glt non turbo engine light
hi all ! i have a 1996 volvo glt non turbo with 180000 miles. i just bought it and it was running great. then all of a sudden the check engine light came on and the car spudders when running. i took it to get looked at by a somewhat mechanic and was told that the # 4 cylinder had low compression. does anyone know if it may be something else a little cheaoer to fix or if it is even worth fixing. how good are these 2.4 engines? thanks
Greetings,
CEL (Check Engine Light) is chronic to some Volvos, including the 850s, and a minor stuff can trigger the light. Didthe mechanicactually use a compression tester, or did you not see him work on your car? I would make it a habit to observe technicians while they work on your car. I would patronise either a dealer or an independentshop that specialises in Swedish/European makes and make them allow me to be in the shop. I would avoid generic garages/franchise shops, as they may not have sufficient knowledge/equipment to properly diagnose & service Volvos.
Visit a local auto parts store to see if they do free diagnostics service, using an OBD-II scanner (On-Board Diagnostic scanner, a hand-held tester that can "talk" to the computer in your car to see what triggered CEL). They can give you the code & the problem. I know AutoZone does it for free (and I usually buy a quart of oil, etc... as a courtesy).
The engines in 850 are known to go over 300,000 miles, if proper care is taken (many people don't). Andthe non-turbo engine (B5254) was designed by Porsche,if I remember correctly. It is hard to believe thatone of the cylinders hassuddenly lost compression; it may be as simple as a fouled spark plug, faulty ignition wire/connections, etc... I would check the ignition system first.
I hope this helps. Also, since this is the new members' greetings area, try posting the same question in the 850 forum; people there have great amount of knowledge and can help you better. This forum is really quiet and not many people come here.
Good luck,
JPN
[IMG]local://upfiles/6892/8A0AFDB5824348598AB340E4A4729655.jpg[/IMG]
Good luck,
JPN
eddiecortes112683
Feb 22, 2009 08:37 AM
