2005 XC70 Headlight circuit out
Old Jan 3, 2017 | 12:06 AM
05xc70's Avatar
Post 2005 XC70 Headlight circuit out
First post here. My driver's side low beam/daytime running light is out. Tried replacing the bulb, checked the fuse and looked for a shunt resistor but couldn't find one under the dash (behind the OBD where there is only a fuse panel that I can see). The bulb is a regular 12V so no high voltage ballast in this model. The open circuit voltage at the bulb connector is 0.7V, the fuse has 12V on it. Has anyone had this problem or can advise me on where the shunt resistor/CEM is located? I presume it has this shunt resistor since this is what gives me the display reading of'bulb failure low beam'. Thanks--Martin in California
bahstunbob
Sep 27, 2020 11:27 AM
Peter1234
Nov 23, 2010 01:19 PM
mikana
Aug 26, 2010 12:47 PM
Shartzy4
Apr 8, 2007 07:33 PM
sk799
May 4, 2006 09:02 PM
