Loss of Power
Old Jun 2, 2014 | 11:47 AM
hdw2050's Avatar
Default Loss of Power
Got an issue with my 2001 Volvo V70. When I turn on my AC I have noticed a lack of power and acceleration. Haven't had a lot of experience with Volvos so am not sure if this is normal. Any Help would be greatly appreciated.
Old Jun 2, 2014 | 05:55 PM
difflock54's Avatar
All vehicles loss a little bit of their pep with the AC switched on.
It also affects the fuel economy.
Approx 10% is commonly stated but usually only noticeable under acceleration or heavier loads, inclines etc.
Old Jun 3, 2014 | 11:17 AM
hdw2050's Avatar
Thanks for you response difflock54, I do understand that there will be some loss, but it seems to be more than the usual 10%. Could this have anything to do with the computer be cause my "check engine light " comes on every time and when I turn it off the light will go out after a while.
Old Jun 3, 2014 | 09:13 PM
difflock54's Avatar
Suggest you get her checked out for any fault codes.
Something is amiss for the CEL to keep coming on. With the codes,if any you will have some definate leads to work on and less guessing.
You may be in limp home mode.
Check the vitals for the engine and transmission whilst your driving her about undiagnosed.
i.e. oil, coolant, ATF etc and visible leaks. Check for loose vacuum hoses too.
Old Jun 4, 2014 | 08:46 PM
difflock54's Avatar
Do you own a fault code reader that reads generic codes and can clear codes?
Alternatively some auto suppliers have them and will read your codes for you free of charge.
They can be bought quite cheaply especially on ebay.
It really is the best starting point as so many issues can be causing the CEL to come on.
Does the CEL light appear with the AC switched off and does the car perform normally whilst it remains off?
Old Jun 4, 2014 | 09:21 PM
difflock54's Avatar
have a read thru this old post from Mathews forum.
Does it sound like it may answer your issues.
http://www.matthewsvolvosite.com/for...hp?f=1&t=40107
Wesley brown
Oct 7, 2014 10:12 AM
S70_5sp
Jul 25, 2012 08:59 AM
sailorflying
Jul 30, 2005 11:37 AM
WHYAYEGTI
Apr 17, 2005 08:00 PM
larwood
Jul 24, 2004 12:32 AM
