Volvo 2006 s60 Please Help!!!!!!
Old Nov 3, 2019 | 07:43 PM
Grumpy8855's Avatar
Default Volvo 2006 s60 Please Help!!!!!!
So i got this 2006 s60 from a friend she doesnt know anything about cars... Its blowing a ton of white grey smoke from exhaust and making a ticking nosie she said it needed left lifter or something so i noticed there was no oil in it so i added 2 qaurrts and then drove home and there was oil all over the engine like it sprayed everywhere cap was on and everything plus i losses power until its warmed up i stopped driving it all together because i dont want to screw it up for good it still starts and is at 175,000 miles what could this be and hiw much will it cost to fix
Old Nov 7, 2019 | 02:56 PM
well you need to figure out where the oil is leaking from. A common problem is the turbo oil return line seal - a $.10 part. The turbo oil return line is on the firewall side of the engine - you'll need to take the heat shield off to see it from the top or look from the bottom. Another possibility is there's an issue with the oil cooler / lines - they go from the front of the engine to the cooler which fits near the radiator. Its possible the car has an issue with the PCV system - there are hoses that come out of the block under the intake manifold go up to the oil separator then up to the intake. If the PCV system clogs, it can push oil out of the filler cap gasket, cam shaft seals. I'd also look at the dipstick to see if that may be loose or leaking. The thing about the gray smoke is whether its coming out of the tailpipe or from the oil being sprayed on the exhaust manifold/turbo. Sounds like you need to clean the engine as best you can, then run it for a bit to see if you can find a fresh trail of oil and go from there.
Old Nov 7, 2019 | 08:26 PM
Grumpy8855's Avatar
So its coming from the tailpipe and the leaking oil was from the dipstick but it is ticking alot also
Old Nov 10, 2019 | 04:49 PM
if you have smoke from the tailpipe you'll need to see if you are consuming oil or coolant. I'd start by looking at the plugs to see if they are black/wet to get a sense if you are burning oil or leaking oil via the valve seals. Oil in the exhaust can be from the turbo seals or oil from the rings/valve seals. Ticking could be a sticky lifter, worn internal parts (bearings, lifters etc).
crotext
Nov 22, 2010 01:06 AM
ibified
Aug 23, 2010 11:34 PM
chrisk
Jun 21, 2010 06:19 AM
1998S70GLT
Apr 23, 2010 07:38 AM
phils94850
Mar 18, 2007 11:25 AM
