Volvo s70 t5 doesn't start after replacing head gasket
Old Aug 26, 2016 | 10:46 PM
livi's Avatar
Default Volvo s70 t5 doesn't start after replacing head gasket
help! my Volvo s70 t5 doesn't start after replacing a new head gasket. i replaced all the cams (intake and exhaust) into its mark
it crank, engine turn so fine, sound like it will start for second but doesn't start.
all plugs are firing but they get wet so easy
Old Aug 27, 2016 | 09:58 PM
What year (ie with or without VVT)? Did you double check the timing marks? did you clean the cylinders when you did the head? if so the walls may be dry and need some oil to help build compression. (ie put a tsp or two in each via the spark plug).
Old Aug 27, 2016 | 11:42 PM
Paul Swider's Avatar
Did you use a camshaft lock? the cams are free spinning and may be off a degree. check the back end of the cam shafts on the back side possibly?
Old Aug 28, 2016 | 11:58 AM
livi's Avatar
i did double check timing set. i even check compression test in every cylinder which is 5,1bar each cylinder.
when i diagnose it tells me that "fuel pressure is too high" and plugs gets so wet easy
tonymite
Nov 22, 2015 07:12 AM
ctullar
Apr 29, 2013 08:05 AM
xDread92x
Mar 31, 2013 02:18 PM
msm15
Nov 12, 2009 10:54 PM
Volvo V70R
Oct 15, 2008 02:41 PM
