1041 axle gear oil
Old Feb 7, 2012 | 10:33 AM
Crispin's Avatar
Default 1041 axle gear oil
I've searched like crazy and need to verify this: My '92 745 has the 1041 rear. I've read that this is not a LSD that needs friction modifiers but rather a lockup type with no clutch. And that I am to use standard 75w90 gear oil. Can anyone please verify this for me? Thanks, C.
p.s. I am so happy that Grandma's wagon that we inherited has the posi rear. This car rocks in the snow and I want to keep it that way!
Old Feb 7, 2012 | 11:28 AM
bubba240's Avatar
check out:
https://customers.volvocars.com/owne...92740_9_1.html
Old Feb 8, 2012 | 08:01 AM
Crispin's Avatar
Thanks for the link bubba but I still have a question. Can I assume that since there is no reference to whether the differential is open or traction lock, then they both use the same lube? Thanks, C.
Old Feb 8, 2012 | 10:30 AM
lev's Avatar
lev
If it has NO CLUTCH (not LSD) then it needs NO LSD oil.
Old Feb 8, 2012 | 03:31 PM
Crispin's Avatar
Yes but I don't know where I read that. I'm looking for confirmation that the 1041 has no clutch.
I searched more today and it seems that the 1041 rear is by Eaton and that it uses a standard GL-5 gear oil (MIL-L-2105 B or C that has been replaced with D that has been replaced with MIL-PRF-2105E which seems to trump all previous oils). Until someone tells me different, I'm going with a good 80w90 (recommended weight by Volvo) API GL-5 dino or synthetic. The Lucas 80w90 sounds like it's pretty robust with lots of additives to reduce the clunk I'm hearing now.
If anyone has more info, I would like to hear it. Thanks, C.
tdrendel
Aug 3, 2021 11:46 PM
secondvolvo
Mar 22, 2012 03:56 PM
carlheat
Oct 25, 2010 10:36 AM
dror_idn
Oct 28, 2009 04:39 PM
