1986 240 DL odometer not working??
Old Nov 23, 2011 | 04:18 PM
Bmxrider07's Avatar
Default 1986 240 DL odometer not working??
My odometer quit working at 129k mi was jw if i need a whole new instrument cluster or maybe could jerry rig something to make it work? Thanks people, btw im still new to this forum so excuse my etiquette lol
Old Nov 23, 2011 | 05:17 PM
Burn Stains's Avatar
Did you reset the trip odometer when it broke? Does the trip read all zeros?
Old Nov 23, 2011 | 05:38 PM
Bmxrider07's Avatar
Yea it resets to 0
Old Nov 23, 2011 | 06:23 PM
Looks like your odometer gear is broken then.
Here are some guides: Volvo 240 Odometer Repair ----- cleanflametrap.com
Can't say I have tackled this myself, but it is easy to remove the instrument cluster...
Old Nov 23, 2011 | 06:26 PM
To remove the instrument cluster if need be... https://volvoforums.com/forum/volvo-...g-57985/page2/
Old Nov 23, 2011 | 11:32 PM
zloetakoe's Avatar
I've had two 240s and replaced the odometer gears on both of them. The hardest part of the job is keeping track of your screws! Very easy job. It is one expensive little gear though. I've decided I'm never going to reset the trip on the 240s again.
Old Jul 2, 2012 | 02:55 AM
jigen3's Avatar
have an 88 245...mine just broke at 192k...it doesn't seem like it's gear related though...
i changed the oil and added a battery disconnect switch today so had to disconnect the battery... and i also had to use a fuel filter wrench and noticed a few sparks as the metal part of the wrench ran across some wires of the alternator accidentally (not sure if the battery was disconnected at this point)...then when i started going i noticed the odometer and trip stopping moving, i'm able to reset the trip tho...
even though it doesn't seem gear related...i'll open it open it up when i get the chance:/
any other insights?
Old Jul 2, 2012 | 12:58 PM
you really should start your own thread, but... if the speedo is workng and the odo isn't, its almost certainly the gear. my 87 240 died at 250243 or something 15 years ago.
Rosy
Sep 11, 2010 10:14 AM
janeofdrama
May 24, 2010 08:02 PM
A96850
Jun 25, 2006 10:06 PM
hillfolk
Jun 19, 2006 09:31 PM
lisrobbe
Feb 27, 2006 09:50 PM
