1988 240 DL wagon turn signal acting strange
Old May 28, 2008 | 11:18 AM
atexasex's Avatar
Default 1988 240 DL wagon turn signal acting strange
I just replaced both headlight/turn signal assemblies (with used ones off an 87 sedan) on my daughters 88 240 wagon in order to get it to pass VA state inspection. The headlights passed (old ones were yellows and cracked) but the passenger side turn signal is behaving strangely. So it flunked inspection anway....
The upper (parking light) bulb is unusually bright and the lower (turn signal light) bulb blinks very weakly. I've swapped #1157 bulbs in and out but no change. The turn signal is blinking veryrapidly on that side as well. The drivers side parking light/signals is fine. When the inspector held the bulbs in bacwards, they seemed to function OK. Also I grounded the light to a bolt on the fender and not behind the windshield washer reservoir as normal.
Any thoughts??
Old May 28, 2008 | 12:57 PM
blue goose's Avatar
Default RE: 1988 240 DL wagon turn signal acting strange
Bad ground connection(s), clean the sockets and terminals. Use a dab of dielectric (tune-up) grease on the connections.
Old May 28, 2008 | 04:13 PM
atexasex's Avatar
Thanks!
Re-grounded it in the right place this timeand cleaned terminals. No difference. Went to the junk yard and got another turn signal and installed it. The way the ground is run from socket to socketis slightly different on this one.
Now the signal is working fine (bright and slow) but the parking light is not working! Swapped out lots of 1157 bulbs but no joy.
RJSV70
2001-2013 model year V70
Oct 28, 2014 03:09 PM
Newport_j
Aug 9, 2011 09:16 PM
RaginRanger
Nov 21, 2009 07:53 PM
raghu9
Apr 1, 2008 03:37 PM
JustGotMineAndLoveIt
Nov 24, 2007 01:50 PM
