1988 240 heater motor replacement
Old Mar 3, 2006 | 03:30 PM
jhall's Avatar
Default 1988 240 heater motor replacement
I'm new to the forum and need some handholding with this project. I'm trying to replace a very noisy heater/blower motor,a job I've done on other cars without much trouble.However,on my '88 240DL wagon after much disassembly it looks like I will have to discharge the AC and disconnect the evaporator as well as the heater core and all the ducts and then remove the entire heater assembly.Can this be?Will it even fit out from under the dash?Any advice or encouragement will be appreciated
Thanks , Jeff Hall, Nahant,MA
Old Mar 3, 2006 | 09:28 PM
Default RE: 1988 240 heater motor replacement
It can be done in the Car. You need to remove the end covers to access the Fan Blades. Then remove them and you will see the screws to remove the motor.
Old Mar 3, 2006 | 11:59 PM
wojeepster's Avatar
It can be done, it is a bear! Most things are easy on a volvo, this one isn't.
Old Mar 6, 2006 | 01:46 AM
pznuttz's Avatar
will this procedure be anymore difficult on my 84'240 Turbo? If it isnt , does anyone have a step by step of this procedure or have any pics of this being done , theres no way Im going to do it the way the Haynes manual says to
Old Mar 6, 2006 | 10:14 PM
jhall's Avatar
Thanks for your responses.I will remove the endcovers as suggested-as soon as it gets a little warmer outside. jhall
Dylanfrancis
Nov 29, 2014 07:52 PM
jdrrxBrick
Feb 16, 2014 01:31 PM
JasnAl
Aug 10, 2013 06:17 PM
jasues
Sep 15, 2012 08:15 AM
wojeepster
Sep 30, 2005 09:13 PM
