1988 244DL idles rough, ok under load, new symptons
Old Jun 18, 2011 | 08:13 PM
  #21
if you got a toasted/bent/broken valve, there's goign to be more than just cleaning up the head, its going to need a valve job ... and if the broken valve stem has wedged in the valve guide, ugh. before I get a new head, I'd take your old head off and inspect for cylinder head damage, as there's no point on putting a new head over a cracked piston or damaged cylinder...
Old Jun 19, 2011 | 07:31 PM
  #22
kwkwhit's Avatar
To all my VF new found friends!
Been conversing over at RWD - The Volvo Owner's Resource and received more good guidance. Turns out that the spring on #4 Exhaust was broken. Enough so that it made that lash noise, but not so broken that the valve contacted the piston. Thinking I have dodged a literal bullet here. New spring and keepers, timing belt, idler, V-Belts, and she should be good to go!
Regards,
Bill
steve240
Jul 27, 2014 10:42 PM
mandobizar
Nov 13, 2012 04:39 PM
woodenyouknowit
Jun 19, 2012 08:29 PM
alltrades
Feb 14, 2012 11:22 AM
drfrankenstein
Mar 25, 2005 09:57 AM
