1988 744 b230et flywhell
Old Aug 24, 2005 | 04:02 PM
muckymechanic's Avatar
Default 1988 744 b230et flywhell
can eneone out there helpme,ive a 740 turbo 88,and im wanting to get my flywhellmachined down,,,,has eneone out there ever done this,and if so what clutch did you use to match back up to the flywheel,or is there a different flywheel i can use....thanks paul...
Old Aug 24, 2005 | 09:17 PM
Default RE: 1988 744 b230et flywhell
Machining the flywheel is suggested before replacing the clutch.
But make sure you mark it somehow before you remove it or you could have trouble.
Mark it with the speed sensor adn make sure it lines back up.Or you could have problems with the car running.
filperez
Apr 20, 2010 07:16 AM
cmanns
Jan 2, 2010 04:13 PM
wendel
May 16, 2009 02:09 AM
Marauder03
May 3, 2009 08:24 PM
96850urbo
Apr 30, 2009 12:52 PM
