1989 volvo 240 wagon rear axle issues
Old Nov 19, 2019 | 03:55 PM
theghoul's Avatar
Default 1989 volvo 240 wagon rear axle issues
Hi! I am a new member but have had volvo 240's for years- this wagon unfortunately ran out of rear end lube and damage was done- refilled and drive now only up to 25 MPH - I am looking for a fix- either changing the whole axle assy. or finding someone to fix what is bad (bearings, gears- ?). I do have a 1988 5 speed that I am considering parting out for this- a shame but havent found another way yet- can someone tell me what vehicles Volvo made that had the same rear end assy. as this one? thanks, bob
Old Nov 19, 2019 | 04:29 PM
are there any markings / part numbers that you can find that tell you the axle ratio on both your car and the donor? - should be either 3.31, 3.54 or 3.73.
Old Nov 19, 2019 | 06:11 PM
theghoul's Avatar
I am not worried by either ratio - mostly interested in what years would bolt in- that is something I willl look for though- thanks! bob
Old Nov 19, 2019 | 06:49 PM
lev's Avatar
lev
I think all RWD Volvos made between 1955 and 1998 have the same rear end, if you don't care about ratios... Some 940/960 have limited slip but apart from that... Plenty of old 240 sitting around you can buy for a couple 'a hundred bucks.
Old Nov 22, 2019 | 01:37 PM
the innards are the same, but the axle housing is quite different between 240 and 7/940, as the two use different thrust arm and suspension mounts. and of course, some 760/960 sedans are IRS so obviously those are different.
svenseven
Jan 6, 2013 07:07 PM
danzo
Aug 28, 2012 03:03 PM
Revolve
Sep 2, 2011 01:51 PM
Kirk Frazee
Apr 24, 2010 07:55 AM
act1292
Nov 10, 2007 06:33 AM
