1990 240
Old Oct 30, 2017 | 10:26 AM
Vladimirmechnik's Avatar
Default 1990 240
My '90 240 has decided to no longer run. It starts, idles fast and stalls. Tune up is done, replaced the vacuum lines to the throttle body. It is not misfiring at all, starts right up, new fuel pumps. filter.... I'm at a loss
Old Oct 31, 2017 | 11:12 AM
lev's Avatar
lev
Clean the Throttle Body and the Idle Control Valve.
Old Nov 3, 2017 | 02:21 PM
beleive's Avatar
check your rubber lines from the tank to main pump. They can be cracked and suck air. i know you would think it would leak fuel but not always the case.
Old Nov 8, 2017 | 11:02 PM
Sambar Stag's Avatar
Vlad, try disconnecting the AMM and starting it. If it keeps on running then the AMM is bad. Make sure the replacement has the same part number ( probably ends in -16).
mattem
May 14, 2020 08:39 AM
craigshensel
Jun 13, 2012 03:11 PM
dldunckel
Jan 20, 2010 07:02 PM
dman777
Aug 7, 2009 03:19 AM
maves75
Feb 3, 2008 04:56 AM
