240 fan pulley clearance
Old Dec 6, 2016 | 02:34 PM
Jill.the.pill's Avatar
Question 240 fan pulley clearance
Hello fellow Volvo enthusiasts!
1987 Volvo 245 base model here. I recently replaced the alternator, water pump, and alternator bushings. I'm now running in to an issue where the adjustment arm for the alternator hits the bottom of the fan pulley.
The adjustment arm doesn't move front to back, only up and down, which would lead me to believe the fan pulley is for some reason too far back (too close to the engine). I'm not sure how this is possible. The new water pump is a GMB purchased from IPD guaranteed to fit an '87 240.
What am I missing? Is there supposed to be a spacer between the water pump and pulley that I lost in the process of replacing? I've scoured the internet and haven't had any luck.
Old Dec 6, 2016 | 06:25 PM
Volvodok's Avatar
The adjuster arm should have 1) a bolt that comes from the backside thru the arm.2)there is a bolt that goes thru the arm and threads into a block that bolt #1 goes thru. Turning bolt #2 adjust the belt tension. Did you replace the belts? Too short belts will cause this also.
Old Dec 7, 2016 | 07:20 AM
jagtoes's Avatar
When you compare the new parts with the old parts you should see what the problem is.
Old Oct 31, 2017 | 10:10 PM
KRH's Avatar
KRH
What is the difference? I too am having the same problem. And already discarded the old pump. Generic fan pulley shims are available at auto stores.
Old Nov 8, 2017 | 11:13 PM
Sambar Stag's Avatar
I've seen that before; I did like KRH did; put a washer on each of the studs before putting on the pulley- works great.
TestPoint
Dec 30, 2013 04:35 AM
guest01
Nov 5, 2011 10:11 PM
RobC
Jan 26, 2009 01:07 PM
TLC_Lover
Aug 19, 2007 09:03 AM
kildagin
Aug 27, 2006 12:00 PM
