1990 245 Ignition switch replacement
Old Jan 30, 2011 | 08:27 PM
darkdelta's Avatar
Default 1990 245 Ignition switch replacement
1990 DL 245
Has anyone ever removed and replaced the ignition switch in 1990 DL 245?
I was going to replace mine today. I removed the bolster, the six torx head bolts holding a cross bar that would allow access to the switch, the upper and lower steering wheel shrouds, and the trim piece that fits over the ignition switch. It is still very securely attached somewhere, that I can't see. Any help is appreciated.
Old Feb 1, 2011 | 09:01 PM
swiftjustice44's Avatar
Fred, are you trying to replace the entire lock cylinder or just the actual switch on the back side?
Old Feb 1, 2011 | 11:00 PM
darkdelta's Avatar
John, Just the switch. There is something I can't see holding it in place. I had done no damage, so I put everything back in place until I could find out what I was missing. Thanks in advance for your wisdom. Fred
jonqu
Sep 9, 2013 12:31 PM
darkdelta
May 23, 2011 10:35 PM
likesspace
Jun 15, 2007 06:34 PM
