1991 740 non-turbo fuel lines
Old Apr 23, 2019 | 07:42 PM
PhilthyBeast's Avatar
Default 1991 740 non-turbo fuel lines
My return fuel hose from the fuel rail was visibly worn and cracked, so I pulled one end free to measure the ID and that was enough to kill it. Leaked badly after reconnecting. It has been replaced.
The supply fuel hose looks OK externally and shows no signs of leaking, but I'm still sketched out about it, knowing that it hasn't likely been replaced since the return line was, if ever. While my general default is to leave things alone if they're not failing/showing signs of failing, this one thing I'm inclined to change out before it becomes trouble.
Can anyone tell me the ID diameter and approximate length of this hose? I'd rather have the replacement part in hand before I begin pulling the old one.
Old Apr 23, 2019 | 07:46 PM
jagtoes's Avatar
The supply hose is a special volvo plastic line with special fittings . It is one piece from the fuel pump to the fuel rail. The fitting at the fuel rail is the special one while the one at the fuel filter is a banjo fitting.
gabanja05
Oct 31, 2022 07:40 PM
jupoloopo
Sep 23, 2011 01:59 PM
playa7970
Sep 23, 2008 11:45 PM
Ricardo12
Nov 9, 2007 06:17 PM
rationull
Oct 30, 2006 03:40 PM
