1991 740 Starting Issues
Old Jul 20, 2018 | 12:31 PM
binyamins's Avatar
Default 1991 740 Starting Issues
My 1991 740 base model has been having inconsistent starting issues lately. When I turn the key to ignition the engine/starter squeals, but does not turn over. At first we thought this was a starter issue, but because of the inconsistency we think there may be a few "bad teeth" on the flywheel. Has anyone experienced a similar issue and fixed it by replacing the flywheel? Or is there something else to try first?
Old Jul 20, 2018 | 06:32 PM
lev's Avatar
lev
What kind of "squeal" are you talking about? Is the starting turning but not engaging the flywheel? If this is the case you need a new starter, the solenoid is not shooting out the drive gear into the flywheel. To make sure, take out the starter and bench test it, and look at the FW teeth while you are at it.
Tom Javor
Nov 30, 2014 10:02 AM
bemerman
Jan 20, 2014 08:18 AM
sven0777
Jul 22, 2013 01:18 PM
micsmessages
May 23, 2011 11:02 AM
brmicbman
Dec 26, 2010 09:07 PM
