89' volvo 740 starting problems
Old May 20, 2011 | 08:50 PM
micsmessages's Avatar
Default 89' volvo 740 starting problems
had a bad starter, replaced it now nothing when i turn the key. i tested the new starter before leaving the store, worked fine. when i arch between the polls on the starter it spins but does not kick out. when i turn the key, dummy lights dim, and i hear click, click, from a relay above where the fuses are. this is driving me crazy. lights are bright, just cleaned terminals at starter and battery, and i have tried starting the car in nuetral and park. the reverse lights come on when in reverse. i am new to this forum, and i just cant figure this out. please help. 89' 740 turbo wagon.
Old May 21, 2011 | 11:28 PM
lev's Avatar
lev
"spins but does not kick out"?
It should kick out to engage into the flywheel. Are you sure the new starter is OK?
Old May 23, 2011 | 11:02 AM
mikesredheap's Avatar
Default starter probs
arcing the starter with a beefy screwdriver across the contacts should start the car if you have the ignition on. If you are getting clicks etc, it sounds like a very bad ground or a big short short somewhere. Check battery terminal contacts, also where the negative cable contacts the body and look for the other engine earth (grounding) point. The current is all pouring away somewhere, so if you take off the ground straps, clean with sandpaper, brush off and replace them that should fix it. Also, the starter grounds through the engine, so take it off and give it a good clean where it contacts the car-you need metal on metal.
If this does not work, you might have an ignition barrel fault (waggle the key a bit), transmission inhibitor switch (you have tried that) or other wiring problem.
Once you sort it, you will probably find that your old starter was fine...I hate it when that happens. I once had so much corrosion in the starter cable there was just a tiny track of good copper down the middle to a dead spot.
monolith
Apr 16, 2008 12:40 AM
penkogj
Aug 23, 2006 10:07 PM
penkogj
Jun 24, 2005 09:49 AM
VolvoLisa
Mar 22, 2005 01:48 AM
bigb1rd
Mar 1, 2005 09:59 AM
