1993 Volvo 240 NA starting issue
Old Sep 1, 2018 | 03:50 PM
MrBric's Avatar
Default 1993 Volvo 240 NA starting issue
Hi y'all, I have a 1993 240 north America. My 240s code box is giving nothing in the ignition code tests. My car right now is turning over but no start, I also have no spark.
Old Sep 1, 2018 | 11:12 PM
MrBric's Avatar
My ignition coil is good I ohmed it out, the distributor also looks fine,
Old Sep 2, 2018 | 07:25 AM
jagtoes's Avatar
Crank position sensor. Do you have spark and do you have gas.
Old Sep 2, 2018 | 12:04 PM
MrBric's Avatar
Yes I have gas, no spark at all. Can I ohm the CPS? If so what is the ohm rating?
Old Sep 2, 2018 | 07:50 PM
lev's Avatar
lev
You can't test the CPS as far as I know, have to replace it... Make sure you get an OEM!
Old Sep 2, 2018 | 11:48 PM
MrBric's Avatar
Well, I decided to check the fuses again and surprise I had a bad one, I re-did the fuse as per clean the flame trap and put a better one in. It now runs like a champ
Old Sep 3, 2018 | 10:40 PM
lev's Avatar
lev
Apparently you had no gas, thus the fuse...
Old Sep 4, 2018 | 11:40 AM
MrBric's Avatar
How can I have no gas if it runs fine? That doesn't make any sense. Neither of my pumps are making a sound
Old Sep 4, 2018 | 11:43 AM
the fuse near the battery is for the fuel injection, not the ignition, thats what lev was referring to.
hansi808
Jan 22, 2018 08:29 PM
hansi808
Jan 18, 2018 01:06 PM
mickmike1980
Jul 21, 2016 05:44 PM
zachmozz
Aug 1, 2010 06:00 AM
dldunckel
Jan 20, 2010 07:02 PM
