1994 with a 240 engine?
Old Mar 12, 2011 | 08:17 PM
vcolper's Avatar
Exclamation 1994 with a 240 engine?
I just purchased a 1994 940 wagon and found it to have the distributor on the front drivers side...like the 240's have. All other 740's and 940's I've seen have the distributor on the cylinder head.
A friend tells me the 940 came like that? He's not my best source of Volvo knowledge, so I ask the group here.
Thanks in advance,
Vic
Guayama, PR
92 240
82 245
Old Mar 13, 2011 | 12:26 AM
Titan Joe's Avatar
I think it's an L block. But I only vaguely remember something about a later model having the front distributor. Is the car turbo?
Old Mar 13, 2011 | 04:43 AM
I believe those are the "Regina" ignition non-turbo 4-cylinders. they also have a different coil, thats more like a block rather than a cylindrical can.
Old Mar 13, 2011 | 01:06 PM
lev's Avatar
lev
Is it possible for the car not to be a US version? I.e, to have started life in Europe or elsewhere? This may explain it... Check the vin #, run a carfax or autocheck on it... Car buyers in Europe especially have always had much bigger choice than in the US. BTW, the Regina cars have the distributors in the head, so does the L block..
Old Mar 13, 2011 | 02:48 PM
swiftjustice44's Avatar
Later cars were seen w/ the block mounted dizzys. I've seen 'em here in the shop so they def made it to the US. I believe all blocks beginning in 93 had piston oil squirters so they were all L blocks. My motor is from a 94 940T, is marked L block, and had a cam mounted dizzy...but I fixed it!
Old Mar 13, 2011 | 03:11 PM
I don't think the late block mounted distributors were ever used on turbo applications, and as far as I know, they were only used with Regina ignition systems. Sorry I wasn't clear earlier, not all Regina ignitions are block mounted, but I'm pretty sure all Bosch are camshaft mounted.
Old Mar 13, 2011 | 06:42 PM
vcolper's Avatar
It non turbo, US spec. and it does have the square boxy Regina coil. I also have a "parts" 940 that has the Regina coil, but it has the distributor on the cylinder head.
Thanks for the inputs.
Vic
Old Mar 13, 2011 | 11:05 PM
Titan Joe's Avatar
Here's another question, are all 93+ blocks squirters with or without the turbo?
ehigazy
Jun 12, 2011 07:30 PM
ravenw
Jul 19, 2010 07:12 PM
hickdead
Aug 9, 2009 02:12 PM
tmmaida
Jun 15, 2008 12:54 AM
flip64
Apr 21, 2008 11:20 AM
