2 Questions?? 1986 volvo 740
Old May 19, 2007 | 04:11 PM
dodgedemon's Avatar
Default 2 Questions?? 1986 volvo 740
Question 1:
how do I get the darn!!!! oil light out there is no switch on the back of the insturment cluster. SOLVED
Question 2:
how would I go about putting a safety nutral switch in my car it is a "1986 740 gle"
Thanks!
Old May 19, 2007 | 04:18 PM
89_240_DL_Sedan's Avatar
Default RE: 2 Questions?? 1986 volvo 740
I don't know about the nuetral safety switch, but the oil light indicates abnormally low oil pressure. Do not drive the car if the oil light is on. Check your oil level, if it is normal you either have a problem with your oil pump or a faulty oil pressure sender.
Old May 19, 2007 | 04:24 PM
dodgedemon's Avatar
it could be the oil presure sender wireing because all the wires out inunder the hood of my car were rotted away so I repleaced all the wires and most of the plug ends and taped it all back up and put shrink tube on it. so i will check that first.
I thought it was juest one of them lights that come on every so many miles.
Old May 19, 2007 | 04:27 PM
There is a service interval light that comes on every 5000 miles or so, but it says SERVICE. Just be careful because that oil press. light is no joke.
Old May 19, 2007 | 04:30 PM
dodgedemon's Avatar
found the problem i never checked any wires that were not in the main harnes and that wire was broke off and grounded out on the block...lol
LinuxMint
Jun 13, 2012 07:51 PM
Yzzerdd
May 4, 2011 12:14 AM
andybot
May 19, 2009 11:29 PM
dodgedemon
Mar 27, 2007 10:14 PM
jonesje
Jan 9, 2006 08:36 PM
